Tune up time
Hey HT.. I need help with my parts list as i've never done a full tune up by myself before..I want to know if my parts list is complete. (even small parts I should change such as washers/gaskets)
my car is a 96 integra gs-r. It currently has 140k miles.
So far i've done the radiator, thermostat, all coolant hoses, coolant, clutch kit, transmission fluid, rear main seal, timing belt and water pump.
My list:
OEM CAP ASSY - (30102-P72-006)
OEM GASKET, CAP - (30132-P72-006)
OEM FUEL FILTER SET - (16010-ST5-E02)
OEM ROTOR HEAD ASSY - (06304-P72-000)
OEM O-RING (30110-PA1-732)
Denso Spark Plug - Double Platinum - OE Type -Part Number: DEN 3172
NGK Spark Plug Wire Set - Part Number: NGW 8018
Complete? Just want to make sure im not missing anything before I order.
(I already have an aem cai so air filter already covered)
Thanks in advance
My list:
Thanks in advance
List looks good to me also, if its your first time doing the fuel filter dont forget to use two wrenches when taking the line off the top (one to hold the filter and one to undo the actual bolt).
might as well buy these and keep in your ride as spares.
you'll need them eventually. getting stranded is a drag man. 8(
http://www.rockauto.com/catalog/more...810&cc=1000427
http://www.rockauto.com/catalog/more...918&cc=1000427
http://www.rockauto.com/catalog/more...290&cc=1000427
zoso
11
Sep 22, 2007 02:53 PM
DarkCyde SI
Jun 22, 2006 10:53 AM
B18C R Spec
Jul 19, 2004 01:58 PM
boostincoupe
Jul 19, 2004 11:06 AM
