Proper Timing Belt Tension for D15B?
I have a JDM D15B not 3stage. I ordered a VX timing belt and a VX water pump along with a Z6 tensioner because the D15B did not have one when I got it.
I got every thing lined up and rotated it a couple times to take any slack out but it still seems way 2 lose to me. It also did not come with a tensioner spring so I took one from a D15B7.. Wondering if thats my issue or if using the Z6 tensioner is the issue?
I can't remember if the spring is the same or not. The actual D15B7 tensioner itself is way different than a D15B Vtec/D15Z1/D16Z6. Btw the D15Z1/D16Z6 tensioner has a slightly bigger roller than the D15B Vtec, I'm not sure if it matters or not, my tensioner was good and I just kind of hoped it never went bad.
Yea thats what I been told.. Although I read some where when ordering a VX tensioner it is the same as the D16z6..
The set up I have is a VX belt and water pump and a z6 tensioner hope I can figure this out need to get this motor running asap.
Do this. The belt really isn't supposed to be all that tight.
In any case you will need to get the engine at TDC, loosen the tensioner adjusting bolt a turn, turn the engine counter clockwise so 3 teeth go up on the cam gear, tighten the adjusting bolt.
Thanks for the help man.. Last question by chance do u have the part number for the z1/z6 spring?
14516-P08-000 SPRING, TIMING BELT ADJUSTER
or
14520-P2A-305 TENSIONER SET, TIMING BELT (KOYO SEIKO)
Look closely at the parts listing for #15, it lists both, one is listed as a spring, the other the tensioner plus the spring, however both have identical prices, I'm pretty sure it doesn't matter which you order, 14520-P2A-305 is what will be on the sticker on the bag that shows up. I'm guessing that the earlier P08 number was at one point just for the spring and now simply supersedes up to the new P2A number, the P08 number is different than the part number for a D15B7/D15B8 which is still available separately, so by that logic it's almost certainly a different spring.
Haleiwa-Brando
Apr 14, 2006 11:17 AM
