d16z6 head d16y7 block
Old Oct 7, 2013 | 09:11 AM
MrChrisDurban's Avatar
Icon6 d16z6 head d16y7 block
hey guys im new to Honda tech and working on cars in general. I am planning on putting a d16z6 head into my 2000 ek hatch. I know my car is obd2b and I need a conversion harness but could someone give me a parts list for this swap? I have been searching and couldn't find one. thank you!
Old Oct 7, 2013 | 09:24 AM
Default Re: d16z6 head d16y7 block
so far I know I need the harness, headstud bolts, y8 head gasket, y8 timing belt
Old Oct 7, 2013 | 11:36 AM
serg86's Avatar
Why not use a Y8 head?
but here is a run down on what you will need.
z6 or y8 head
y8 or z6 intake manifold
timing belt for a y8 or z6 depending on head
y8 head gasket
intake gasket depending on which one u use
new head bolts or arp had studs
anti freeze
engine oil (recommended)
spark pugs
spark plug wires
i would get also
new water pump
new timing belt tensioner
new exhaust gasket
new valve cover gasket
heater hoses, because regardless of intake you will need to extend some
unless u use the shitty y7 intake
new oil pump (my opinion not necessary)
if this is to vague here is a write up done here already on a different block but basically the same thing
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
sleepinef
19
Sep 14, 2009 04:01 PM
mario_pic
Nov 21, 2008 08:12 PM
jewpont
10
Oct 12, 2008 03:49 PM
rice a roni
Oct 8, 2004 08:39 AM
pro547
Jun 12, 2004 09:21 PM
