Just bought 95 Civic Dx. Need some help?
Old Oct 6, 2013 | 03:19 PM
TurboKitty@1's Avatar
Default Just bought 95 Civic Dx. Need some help?
It runs great, but it seems like the clutch is having a hard time engaging or something. It shifts into each gear w/o any grinding, but when I release the clutch it takes a few seconds to shift into the gear. Almost like the pedal is getting stuck but slowly goes into gear. Any Ideas?
Old Oct 6, 2013 | 05:58 PM
B_Swapped93's Avatar
Default Re: Just bought 95 Civic Dx. Need some help?
so it's slow to "catch" does it feel like it's slipping ?
Old Oct 7, 2013 | 05:02 AM
Yeah like pedal gets stuck coming back from the floor and doesn't fully engage. But every gear stays in, no grinds or anything.
Old Oct 7, 2013 | 09:23 AM
check to see if there is a leak at the top of the clutch pedal where it connects to the CMC(clutch master cylinder). then see if the slave cylinder is leaking it's mounted on the tranny. 3rd thing I can think of is the clutch pedal free play is not adjusted properly.
Old Oct 7, 2013 | 11:44 AM
Well I just bought it. The guy replaced the master and slave cylinders and said it was doing it prior to the replacements. I dont see any leaks near either.
Old Oct 7, 2013 | 02:31 PM
Somebody told me that it could just need to be bled again. Someone else said its definitely a clutch. So Im not sure which way to lean.
Old Oct 8, 2013 | 02:00 PM
Nobody else?
dsturch1
Mar 26, 2011 07:15 PM
lo0nY
Feb 26, 2006 03:58 PM
herbalist
Mar 25, 2005 07:59 PM
mdj_ge
Dec 3, 2004 06:45 AM
VTECVillain
Mar 26, 2003 04:49 PM
