Clutch Possibly Going?
Hey guys, I just got a 98 EX Coupe today. I was wondering if someone could maybe point me in the right direction. In order to engage the gear - the gear engages after releasing the pedal not too far from fully depressed. Is this a sign that the clutch may be on its way out? When driving, the pedal does not need to be depressed very far to release the car from the gear it is in. Any insight is greatly appreciated! Thanks in advance
Re: Clutch Possibly Going?
hes saying that the clutch is engaging at a low point in the pedal
this usually means the master cylinder or the slave is going out
or
the guide pin behind the clutch pedal needs to be adjusted (most likely case is the bad MC and slave)
or
alot easier than having to change a clutch
labor is simple EXCEPT for unbolting the mastercylinder from the firewall inside the car
without useful tools like a swivel and deep sockets, you'd get pretty aggravated cause of how unconfortable it is under there
but its not hard to tackle, a noob could handle it in a couple of hours. bullsh!tting included
i usually do the master cylinder first, get all of the hard stuff out the way first, then do the slave, theres really no order, just recommended that you replace both the MC and SC at the same time.
then you bleed the system of air and recommended flush it with fresh fluid after you replace everything
just to be sure, after re reading your first post
the clutch grabs at a point very low in the pedal?
when your letting off the clutch from, say, puling forward, the clutch grabs almost instantly?
