92 Civic Hatch looses brake pressure
Old Oct 6, 2013 | 05:52 AM
JDiamond's Avatar
Default 92 Civic Hatch looses brake pressure
So I have a 92 civic hatch back and its been loosing brake pressure when i push the petal like say in the morning it goes all the way down and then I pump it some and gets normal and a little later it goes right down to floor again. Any Ideas on why it could do that?
Old Oct 6, 2013 | 03:47 PM
JDiamond's Avatar
Default Re: 92 Civic Hatch looses brake pressure
Bump need help
Old Oct 6, 2013 | 04:01 PM
carlos8's Avatar
are you loosing fluid in the reservoir? any sing of fluid in your garage floor?
Old Oct 6, 2013 | 06:51 PM
pelayo114's Avatar
Sounds like a master cylinder.
Check for leaks at the calipers, and brake cylinders if you have drums. As stated, check fluid levels at the master cylinder and for leaks around it in the engine bay and the cabin.
Old Oct 7, 2013 | 11:28 AM
JDiamond's Avatar
theres no leaks just a loss of pressure might be the brake cylinders didnt think of that
Thanks
Old Oct 7, 2013 | 05:58 PM
Dontoh's Avatar
If there's no external leaks, it could be internal too don't forget. For example, your master cylinder. When you "lose pressure" does the car still stop properly, or will it keep moving forward no matter how hard to press the brake pedal?
Old Oct 8, 2013 | 03:52 PM
JDiamond's Avatar
Honestly don't know I just got it last saturday and dropped in an engine and came to discover this problem I checked for leaks and nothing everythings seems to look good. just the pedal goes to the floor and after you pump it up its normal for a while. To scared to run it lol
amagoun1
May 23, 2012 04:41 PM
draperj09
17
Oct 18, 2007 03:03 PM
TedR719
May 21, 2003 07:54 AM
eg_92vxhb
Jan 8, 2003 02:58 PM
Angry Joe
Jul 24, 2002 05:17 AM
