Front speakers - not working
Old Oct 5, 2013 | 01:09 PM
dwb1974's Avatar
Default Front speakers - not working
hi,
the driver's side speaker at the front stopped working, but the other 3 continue to work. I have replaced both front door speakers with new Pioneer compatible, as I had believed that the speaker was N/S; however, even the new one doesn't work. The twin installed does.
What could the problem be? Fuse box??
thanks
Old Oct 5, 2013 | 02:40 PM
95Sedan's Avatar
Default Re: Front speakers - not working
you have a broken wire in the door from the wires being old/opening and closing the door.
This is common on many vehicles. Split the insulation if anything and re connect/solder the wire back together and you will be fine. Then tape everything back up
Old Oct 7, 2013 | 02:41 PM
GsrGoRawr's Avatar
before u go ripping your electrical system up check to make sure all the connections behind your radio are connected properly. I had the same problem and it was one wire from the radio not completely connected.
Old Oct 10, 2013 | 10:23 AM
Cody Pereira's Avatar
you can always check for continuity at the speaker (making sure that you have complete circuits for both your ground wire along with your speaker feed). I had a problem similar to this, but instead it took out the entire channel when the ground wire shorted out on the door frame. I would start off by checking for continuity. Good luck!
Old Oct 15, 2013 | 04:32 AM
dwb1974's Avatar
Thanks for the advice.
I plan on bringing it into the shop, and I do suppose something is loose in the connection just simply because all the other speakers work so it can't be a fuse then.
Have a great one!
Honda Nub
17
May 12, 2013 11:55 PM
mstr2
Audio / Security / Video
Nov 22, 2012 11:14 AM
Kavehman
Jun 21, 2004 09:53 AM
Rob Dizzle
Feb 19, 2002 10:50 PM
kepani
Jun 3, 2001 05:18 AM
