testing ICM and coil with Multimeter need help
so i read this article...
http://www.team-integra.net/forum/bl...eshooting.html
and I have found a couple things out... between the ground on the coil terminal and the ICM i am getting less than 12V.... (not good)
Now when I am testing between the two terminals on the primary coil, i set the meter to lowest possible reading which is 200 ohms... i get 2.2 on the primary coil, (i dont know what that means if it is bad or good) i have 2 dizzys and I know one is bad from the tuner... just checking to see if I am doing this correctly. (note harbor frieght multimeter $5 POS)
anyone care to chime in for some edumacation?
