testing ICM and coil with Multimeter need help
Old Oct 5, 2013 | 11:43 AM
supersilverdc2's Avatar
Default testing ICM and coil with Multimeter need help
so i read this article...
http://www.team-integra.net/forum/bl...eshooting.html
and I have found a couple things out... between the ground on the coil terminal and the ICM i am getting less than 12V.... (not good)
Now when I am testing between the two terminals on the primary coil, i set the meter to lowest possible reading which is 200 ohms... i get 2.2 on the primary coil, (i dont know what that means if it is bad or good) i have 2 dizzys and I know one is bad from the tuner... just checking to see if I am doing this correctly. (note harbor frieght multimeter $5 POS)
anyone care to chime in for some edumacation?
Old Oct 5, 2013 | 11:45 AM
Default Re: testing ICM and coil with Multimeter need help
Note secondary coil test is getting about 15.6K
Old Oct 6, 2013 | 10:38 AM
tamboo's Avatar
10 Year Member
meltman....with the power to melt!
elpiar
Sep 28, 2005 06:16 AM
Origin
Mar 28, 2004 04:57 PM
