Car cranks but doesnt start. Low fuel pressure?
Old Oct 5, 2013 | 10:45 AM
TheDonOG's Avatar
Icon2 Car cranks but doesnt start. Low fuel pressure?
My car would take a couple cranks to get started sometimes. Never had an issue with it not starting. I parked it for a couple of days and now its not running. Previous owner told me it was most likely the fuel pump but I figured it would not run at all if the pump was bad. I hear the whizzing from my fuel pump. I checked all of my fuses. Any ideas before I start fixing things that aren't broken? or any ideas?
Old Oct 5, 2013 | 11:46 AM
supersilverdc2's Avatar
Default Re: Car cranks but doesnt start. Low fuel pressure?
check distributor they are notorious for going bad, did you check for spark?
http://www.team-integra.net/forum/bl...eshooting.html
this may help
Old Oct 5, 2013 | 03:38 PM
TheDonOG's Avatar
I have an aftermarket distributor! I'm thinking the fuel filter could be clogged is that plausible?
Old Oct 6, 2013 | 09:49 AM
fcm's Avatar
fcm
Old Fart
A fuel pressure gauge would answer your questions, just install one permanently.
As mentioned, check for spark, use an HEI spark tester. 94
Old Oct 6, 2013 | 10:33 AM
tamboo's Avatar
10 Year Member
or go low tech lol.
i actually saw an integra with one.
Amazon.com : Stens 120-436 Fuel Filter Replaces Kohler 25 050 22-S John Deere AM116304 Exmark 109585 Bobcat 38666 Onan 149-2206-01 Gravely 21541500 Toro 98021 : Lawn Mower Parts : Patio, Lawn & Garden Amazon.com : Stens 120-436 Fuel Filter Replaces Kohler 25 050 22-S John Deere AM116304 Exmark 109585 Bobcat 38666 Onan 149-2206-01 Gravely 21541500 Toro 98021 : Lawn Mower Parts : Patio, Lawn & Garden
Old Oct 7, 2013 | 10:10 AM
TheDonOG's Avatar
I already have a fuel pressure gauge and it is showing low pressure. That is how i came up with the assumption that the fuel filter is clogged and i know that the fuel pump is ok. But i will check for spark first thing and keep this updated. Thanks i really do appreciate the help.
Old Oct 7, 2013 | 06:08 PM
Eg.ls.turbo's Avatar
If u low on fuel pressure then it's probably ur fuel filter or fuel pump. Change fuel filter first cause they cheap.
marcosenid
Oct 30, 2008 04:52 PM
SiRay13
Oct 30, 2006 01:29 AM
ronqqq
Jun 2, 2005 07:11 PM
imported204
Mar 13, 2003 06:30 AM
Yellow Dragon
Aug 26, 2001 04:38 PM
