weird front end bouncing??
When I get over 35 mph my front end seems to shake. Almost like the wheels are unbalanced or uneven. i swapped the spare tire for each of the wheels to try to pin point of one of the wheels was unbalanced. but i still have the problem. im lowered and tires have some camber ware. Any ideas??
this is what happend
i drive home from school. got home everything seemed fine. left my house a few hours later start driving and it was shaking really bad. pulled over looked at the sway linkages. get back it it wasn't as bad. went home tightened all the suspension parts. my tires do have a little camber ware tho but i was driving fine on them fine before.
Got a back alley garage to balanced my fronts and shook like crazy.... took them to local firestone and they did the job right the one wheel weight was way off after they got done rides super smooth.. Might be something to look into.
and it wouldn't make much sense because ive been driving on these tires for about a year. did rotations and everything. and they were running smooth the other day..
Update.
55mph seems okay. Annoying over our while accelerating car shakes. What could this be? It almost feels like it shakes left and right. Could it be motor mounts? Help!? I need this car
Have you checked the axle nuts to see if they are tight ?
How about the wheel bearings ? Grab the bottom, and top end of the tire and shake it back and forth to see if you have any play.
I took the front driver side where off pushed and pulled at the axle. It was the problem.. I swear I checked that like 4 times. Took it apart. Bearing exploded inside. Replaced it everything is great now!
