bottem end....wha to look out for
Old Oct 3, 2013 | 01:29 AM
RS 500,'s Avatar
Default bottem end....wha to look out for
Hi chap.
what to look out for on a bottom end.2.2 Ha.. just bought a Accord type r with engine knocking..
im going to source a new bottom end.. i need to know what to look out for.
is it true a type r crank can not be reground.
many thanks
sorry if wrong section
Old Oct 3, 2013 | 05:29 PM
Eg.ls.turbo's Avatar
Default Re: bottem end....wha to look out for
For bottom end knocking I would look for bent rods, take ur rod caps off and inspect bearings for wear and tear, also check ur crankshaft to see if it's been scarred
Old Oct 4, 2013 | 03:05 PM
93egSLEEPER's Avatar
First thing I would do is get an oil pressure gauge on it. Start the car and take the oil cap off and peek in to see if there is enough pressure squirting oil in the head properly. If it is and it's reading low oil pressure, its more than likely spun bearings. I'm not a fan of turned cranks to begin with so I would just look to replace the crank, all bearings and have the rods checked for roundness.
TooFastVTEC
May 16, 2013 08:53 AM
Running925
Jul 3, 2008 06:06 PM
Aquafina
28
Jan 16, 2008 10:55 AM
jarven093
Apr 28, 2007 07:57 AM
toooslow
Oct 15, 2003 10:47 AM
