Two Questions About S2k
hi guys, im relatively new s2k owner, i hv couple questions wanna ask to get better understanding of the car
1st: every time when i break so hard, the yellow exclamatory mark flash on the dash and i have mechanical feeling on the break, i know when i turn off the VSA, that yellow exclamatory mark will always on, but what is that flash means? does that means the ABS kicks in or the system kicks in???
2nd: how to adjust the handbreak? the handbreak is kind of loose now, i know how to adjust the handbreak with drums, not with disc.
Guest
Posts: n/a
1st: every time when i brake so hard, the yellow exclamatory mark flash on the dash and i have mechanical feeling on the brakes, i know when i turn off the VSA, that yellow exclamatory mark will always on, but what is that flash means? does that means the ABS kicks in or the system kicks in???
2nd: how to adjust the handbrake? the handbrake is kind of loose now, i know how to adjust the handbrake with drums, not with disc.
i dont have an 06 so i duno about all dem fancy features so i cant help with the light.
but with the e-brake don't b a ******* idiot, just tighten the cables. remove center counsel locate 10mm nut righty tighty lefty loosie
Cool Cool Island Breezes. BOY-EE
The VSA light flashes if you lose traction (heavy braking, acceleration, etc). It's letting you know that VSA is active. If it's turned off, the light will just stay on solid
msinsky14
Nov 29, 2006 08:44 PM
Dawsonb17a
Jun 22, 2004 07:50 AM
