Best Cam upgrade from Crower 63401T's
I know cam selection can be a dark art, with many variables. My setup is as follows:
2.0 LS/VTEC
84x89mm
9:1 CP with upgraded pins
Eagle Rods with L19 rod bolts
Sleeved
GSR main cap Girdle
ARP's
B16A head (mild clean-up)
Supertech Valvesprings + Ti Retainers (SPR-H100DR 85 lb)
Supertech Valves +0.5mm
Crower 63401T-2 cams
Stock B16A intake manifold
Holset Super HX40 (69 lb/min)
1.25" diameter twin scroll manifold
3" downpipe and full exhaust
E97
1600cc injectors
Full blown dual hanger with 2x DW 300 pumps
Upgraded fuel lines
The car has made 540whp on a Dynapack at 22 psi at 5500 ft elevation. Power did not increase past 22psi.
I now want to change the cams and intake manifold to increase power to around 650whp. Options I'm considering:
GSC T1
Skunk Tuner 2's
BC Stage 2 (NA cam)
CTR's (although hard to find a decent set)
Victor X intake manifold
Please help
2.0 LS/VTEC
84x89mm
Sleeved
GSR main cap Girdle
ARP's
E97
1600cc injectors
Upgraded fuel lines
GSC T1
Skunk Tuner 2's
BC Stage 2 (NA cam)
Please help
Those turbo cams aren't helping but at that elevation you seem to be close to be limit of your turbo. Cam upgrade might help some but not a whole lot.
Tuner 2's don't do well with boost. Stage 2 be an cams I would bother with. Go with skunk2 tuner 1's or gsc t1 cams if you are going to replace yours.
I will get the boost plot from the tuning shop
When you guys say I am close to the limit of the turbo, do you mean airflow vs PR required or something else ?
The Turbo's compressor map shows that it can support +- 65 lb/min even at a PR of 4
Thank you for the replies
The air flow number you are quoting is at elevation and std conditions. By my estimation, you are at 60 lbs/min which is the limit at your elevation.
Is my understanding correct ?
Angel4768
Nov 4, 2012 04:09 PM
em1effekt
Dec 2, 2010 11:51 AM
guy_from_nerk
Nov 7, 2009 10:46 AM
