Best Cam upgrade from Crower 63401T's
I know cam selection can be a dark art, with many variables. My setup is as follows:
2.0 LS/VTEC
84x89mm
9:1 CP with upgraded pins
Eagle Rods with L19 rod bolts
Sleeved
GSR main cap Girdle
ARP's
B16A head (mild clean-up)
Supertech Valvesprings + Ti Retainers (SPR-H100DR 85 lb)
Supertech Valves +0.5mm
Crower 63401T-2 cams
Stock B16A intake manifold
Holset Super HX40 (69 lb/min)
1.25" diameter twin scroll manifold
3" downpipe and full exhaust
E97
1600cc injectors
Full blown dual hanger with 2x DW 300 pumps
Upgraded fuel lines
The car has made 540whp on a Dynapack at 22 psi at 5500 ft elevation. Power did not increase past 22psi.
I now want to change the cams and intake manifold to increase power to around 650whp. Options I'm considering:
GSC T1
Skunk Tuner 2's
BC Stage 2 (NA cam)
CTR's (although hard to find a decent set)
Victor X intake manifold
Please help
2.0 LS/VTEC
84x89mm
Sleeved
GSR main cap Girdle
ARP's
E97
1600cc injectors
Upgraded fuel lines
GSC T1
Skunk Tuner 2's
BC Stage 2 (NA cam)
Please help
Re: Best Cam upgrade from Crower 63401T's
Those turbo cams aren't helping but at that elevation you seem to be close to be limit of your turbo. Cam upgrade might help some but not a whole lot.
Tuner 2's don't do well with boost. Stage 2 be an cams I would bother with. Go with skunk2 tuner 1's or gsc t1 cams if you are going to replace yours.
I will get the boost plot from the tuning shop
When you guys say I am close to the limit of the turbo, do you mean airflow vs PR required or something else ?
The Turbo's compressor map shows that it can support +- 65 lb/min even at a PR of 4
Thank you for the replies
Is my understanding correct ?
Angel4768
11-04-2012 04:09 PM
em1effekt
12-02-2010 11:51 AM
guy_from_nerk
11-07-2009 10:46 AM
