itr valvetrain to b16a head?
Old Sep 26, 2013 | 10:03 AM
PabloM's Avatar
Default itr valvetrain to b16a head?
could i or should i do it? how much hp would it be gaining or how much rpm could i raise with this?
i understand the itr has 2 valvespring on the intake side and maybe stiffer on the exhaust side?
thanks!
Old Sep 26, 2013 | 10:08 AM
doood's Avatar
been there done that
Default Re: itr valvetrain to b16a head?
could you? yes
should you? depends
how much hp? nobody knows
Old Sep 26, 2013 | 10:33 AM
Deetz's Avatar
Crazy Honda Guy
You could just add the 2nd valve spring to your exisiting exhuast valves and call it a day.
Changing the valves may be a different stoey, as they are cut at a differetn angle meaning you have to get the head sent in to mtch up the seats
how much power to be gained, it would pretty much be the same, just be able to rev a touch higher
Old Sep 26, 2013 | 11:50 AM
xyzalvarez's Avatar
true. Replacing the valves without adding a new upgraded cams will only help you to rev
higher but you won't see a lot of gains other than revving to 8500 rpm.
Even replacing the valves with a set of flat valves will increase the CR by a hair and you
won't see any substantial gains for the work being done.
My .02 cents will be to spend that money on a air/fuel tune and maximize your actual engine setup. Save $ to get nice set of cams with an upgraded set of valve springs.
Old Sep 26, 2013 | 02:51 PM
PabloM's Avatar
so you recommend to upgrade the valve springs and retainers with a set of cams
thank you all for the replies!!
Old Sep 26, 2013 | 03:09 PM
Deetz's Avatar
Crazy Honda Guy
Personally, i think that retainers are a waste
Sure, the aftermarket ones are ever so slightley lighter, BUT, they are also softer, and really have no performance factor. The stock oem retainers are just fine, why spend more $$?
Most people upgrade valve springs to accomadate the lager more aggressive lobes on aftermarket cams and avoid valve float at higher rpm....every engine goes by these rules
Old Sep 26, 2013 | 03:17 PM
PabloM's Avatar
what about supertech valve guides? valve keepers? does they worth the money?
do i need supertech retairners if i buy dual valve springs?
thank u!
RMXmitch
15
Nov 29, 2007 02:55 PM
turbohf
Feb 4, 2007 06:09 PM
Boosted Chemist
Nov 21, 2004 03:39 PM
MysteriousGSR
Mar 28, 2003 12:40 AM
kappa
Nov 18, 2002 12:48 PM
