Replacing valves.
Old Nov 17, 2002 | 07:52 PM
kappa's Avatar
Default Replacing valves.
I'm in need of a new valvetrain (B18B) soon, I do not know too much about internal engine work so I was wondering if I should upgrade the valves to aftermarket rather then stock? Is it worth it or would I have to do some major upgrading to other internals for it to all work together for noticable gains? I'm a n00b to this subject so your help is appreciated.
Old Nov 17, 2002 | 09:17 PM
kappa's Avatar
Default Re: Replacing valves. (kappa)
anyone???
ttt
Old Nov 17, 2002 | 09:53 PM
the DR.'s Avatar
What are you trying to accomplish exactly.. are you putting in new cams?
Old Nov 17, 2002 | 09:57 PM
brian b's Avatar
New User
Always upgrade valves, the stronger they are the less chance you'll have of breaking one and having to spend mass cash to fix your head, turbo and pistons.. I've got Ferrea comp plus valves and they saw 10700 rpm today in a b16a head due to a miss shift without any problems
Old Nov 17, 2002 | 09:58 PM
98acura's Avatar
Default Re: Replacing valves. (CIVICtypeS)
If your goal for your car is performance, then by all means, while your in there, put upgraded aftermarket valves in, they will allow you to go to higher rpms, therefore creating more power, if your car is just transportation, or if your going for show, then dont bother with aftermarket valves. Stock will work fine.
Old Nov 17, 2002 | 10:36 PM
kappa's Avatar
Default Re: Replacing valves. (98acura)
I am unsure of how far I'm going with my B18B. It already has roughly 105,000 on it (1994 LS). Basically, I was wondering if it was worth it (overall) to upgrade the valves by itself, without consideration of upgrading cam gears/sprockets/ect. I may or maynot perform those mods. If I were to keep my LS engine for longer then expected, I would most likely head in the direction of Naturally Aspirated. Thanks for your guys' help. Keep the info coming!
Old Nov 17, 2002 | 10:55 PM
EVOCELICA's Avatar
New User
not worth it IMO. If you decide to run some nitrous or any other form of forced induction then i would. Upgrading valves is good for preventing burnt valves, with a good stainless steel valve you will melt a spark plug before you burn a valve. Burnt valves accure when you run extremely lean, unless you are really building a high horse power LS I wouldn't bother.
Old Nov 18, 2002 | 12:25 PM
kappa's Avatar
Default Re: Replacing valves. (EVOCELICA)
hmm interesting .. different opinions from everyone, expected though.
Old Nov 18, 2002 | 12:47 PM
EVOCELICA's Avatar
New User
I believe skunk2, ferreras, manlys are like 20 something dollars per valve. Really not worth it unless you are building a race car.
Old Nov 18, 2002 | 12:48 PM
EVOCELICA's Avatar
New User
also don't expect any hp gains from aftermarket valves on a semi stock B18b
Dr.Honda
Nov 4, 2007 10:48 AM
Magnum000
Nov 22, 2003 05:11 AM
advanracing62
Oct 3, 2002 09:43 AM
Allstar
Apr 30, 2002 07:54 PM
Integra91LS
Feb 28, 2002 02:16 PM
