Intalled New IM on Boosted Hatch But problems
Old Sep 24, 2013 | 04:12 PM
JHipps's Avatar
Default Intalled New IM on Boosted Hatch But problems
Okay guys here is the rundown on my car. If you need any more info please ask.
B16 Head
-Supertech Springs/Retainers
-Stock Cams
B18A1 Block - Stock
Garret gt28r .60 trim turbo
2.5' piping all around
750cc r/c injectors
So I had the stock intake manifold and throttle body on there. I bought a Performer X intake with a Pro. Products 65mm TB. The TB came with TPS and Map sensor. My b16 did not have a map sensor on it. When I start it up, my air/fuel reads 10.0 and smoke comes out the exhaust. Soooooo I am not sure what to do from here.. Any help will be appreciated
Old Sep 24, 2013 | 04:21 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Intalled New IM on Boosted Hatch But problems
Your car didn't have a map sensor but it ran??? Doubtful
What's the rest of your setup, engine management, was it tuned etc
Old Sep 24, 2013 | 04:22 PM
wantboost's Avatar
Who is Mr Robot?
How do you like the gt28r? I have one sitting around I've been debating about using
Old Sep 24, 2013 | 04:48 PM
JHipps's Avatar
P28 Ecu chipped on Chrome
Old Sep 24, 2013 | 05:11 PM
sp00led's Avatar
Didn't the b16 have the map sensor on the firewall opposed to the b18 which has it on the throttle body? Did you connect the new MAP sensor?
Old Sep 24, 2013 | 05:18 PM
JHipps's Avatar
Well this is in an eg hatch not the original car the b16 is in. And no i left it unconnected. Well on one start i disconnected the plug that goes to the tps into the map sensor on the TB but it did the same thing
Old Sep 24, 2013 | 05:44 PM
hon2984's Avatar
I would locate your original MAP sensor and use it.... Changing MAP sensors can cause problems....Depending on the amount of readable bar determines the scale....hondata has preprogrammed scales for many map sensors, GM 3bar, Omni 4 bar etc. not sure about crome....
You should also check the TPS sensor to see if it is adjusted correctly.
Old Sep 24, 2013 | 05:46 PM
JHipps's Avatar
Any idea where the original map sensor would be?
Old Sep 24, 2013 | 05:57 PM
ballistic1350's Avatar
Post up some pics and we'll help you out
Old Sep 24, 2013 | 06:00 PM
sp00led's Avatar
There should be a vac line going from the intake manifold to it.
Old Sep 24, 2013 | 06:03 PM
hon2984's Avatar
i dont neccessaring mean the oem one....just saying the one that was used when it was running on the stock intake mani... it could have a map sensor tucked somewhere....look for a vacuum line connected to a sensor with 3 wires.
Old Sep 24, 2013 | 06:16 PM
JHipps's Avatar
Is this the original map sensor?
Old Sep 24, 2013 | 06:22 PM
hon2984's Avatar
yes....wondering why there is a tee off of it.... is the vacuum line connected to a vacuum source...it will basically think its wide open throttle without boost if it does not see vacuum....
Old Sep 24, 2013 | 06:38 PM
JHipps's Avatar
I disconnected it, plugged it into the current map sensor and it sounds perfect but the throttle cable was not connected. Would it be the same after i remount it?
Old Sep 24, 2013 | 06:45 PM
JHipps's Avatar
OK yeah just tried it. It is idling high
Old Sep 24, 2013 | 06:53 PM
JHipps's Avatar
That hose that you see there runs off and is just dangling. It is not connected to anything
Old Sep 25, 2013 | 05:13 AM
hon2984's Avatar
adjust the throttle cable... and you still should check the tps voltage to see if it is adjusted correctly as well. if that hose is connected to vacuum and the other end is hanging open that is a vacuum leak and can also cause a high idle.
Old Sep 25, 2013 | 01:23 PM
wantboost's Avatar
Who is Mr Robot?
And?
JHipps
Engine Management and Tuning
Sep 30, 2013 06:32 PM
SVOboy
Mar 26, 2006 11:48 AM
kechup2eg6
Aug 10, 2005 07:47 PM
pissedoffsol
Apr 30, 2003 08:42 PM
