Leaking axle seals Zc swap
Old Sep 23, 2013 | 06:15 PM
Nottjbarlow's Avatar
Default Leaking axle seals Zc swap
About two years ago I did a DOHc swap, everything was fine but I was slowly losing oil through my axle seals. I also rebuilt the transmission A little while ago fifth-year HF hybrid tranny all has been working well after the sychrotech rebuild, but now my brand-new axle seals are leaking again. I also changed them twice they are still leaking, BAD, again! I even tried a lil grease on the inside lip of the seal, where it meets the axle seal surface on the second set of seals, I'm using brand-new Acura Integra b18b axles (well 1000mi on them). What is going on????
P.s. It is only leaking on the passenger side.
Old Sep 24, 2013 | 02:59 AM
Freemananana's Avatar
Default Re: Leaking axle seals Zc swap
Is it all the way seated and are you sure it's coming from the trans? It sounds like you are saying that the axle and trans aren't making a good seal and there is fluid leaking. Right? Sure it's not leaking from above? Maybe you have a torn boot and it's just grease.
Old Oct 4, 2013 | 07:36 AM
i can watch oil come right out of the axle where it meets the trans... not grease no boot issues, like i said the axles are brand new). the only thing i can think of is that maybe i am using the wrong seals??????/ either that or they are just made-in-china crap! does anyone know what the specified ones are supposed to be.
please help i've probably leaked 10 gals of oil onto the streets of south Fla over the past 3 weeks and im pretty sick of squeezing oil into the trans, also my wallet hates me
Old Oct 4, 2013 | 04:40 PM
swordofdoom's Avatar
Your seal may not be seated right and sitting in crooked. The other thing to check is to make sure you don't knock off the small metal ring that sits on the inside of the lip. I did that once before but noticed it on the ground right before I hammered it in to the tranny.
driveslow
19
Mar 5, 2009 07:03 PM
itsLOUiSduh
Oct 17, 2008 12:31 PM
HBK
10
Apr 22, 2006 11:17 AM
civicjoe8
Apr 11, 2006 08:52 PM
Jer'rome
Sep 30, 2004 06:14 PM
