1995 Acura Integra Crank, No Start
Old Sep 21, 2013 | 09:02 AM
bdlawnic's Avatar
Default 1995 Acura Integra Crank, No Start
Alright chaps its your favorite person back again with Integra issues.
My 1995 Integra SE Autotragic is in crank, no start mode.
The compression numbers are 100,90,90,100 but it had to be tested cold because of the no start issue.
The fuel pump is buzzing when the key is turned and if you spray starter fluid in the intake it will still crank but not start.
The ignition is possibly weak as when I checked it the spark appeared orange. However the spark is present.
Where do I go from here lads?
Old Sep 21, 2013 | 11:18 AM
Declectic's Avatar
Default Re: 1995 Acura Integra Crank, No Start
Your battery could be weak, if you can jump it and it starts then you know u need a new battery. Otherwise your looking at distributor type issues.
Old Sep 22, 2013 | 07:20 AM
tamboo's Avatar
10 Year Member
i've worn out 4 ignition coils so far, that might tell you something.
2 of them were chinese cheapies that tend to go **** up within a year.
Old Sep 22, 2013 | 07:46 AM
bdlawnic's Avatar
I have ordered a coil. It sounds like the problem. Thanks guys.
Old Sep 28, 2013 | 12:13 PM
bdlawnic's Avatar
BUMP.
Sorry to bring this back friends but the car is still cranking but not starting.
A new distributor went in this afternoon and the dang thing still wont turn over.
Also the oil pressure light and battery light both stay on while I attempt to crank the car.
Any ideas? What should I look for/at?
Old Sep 28, 2013 | 09:52 PM
TheRealTegger's Avatar
When you crank and the engine won't start, does the tach needle jiggle just the tiniest amount, or is it dead-still?
Old Sep 29, 2013 | 05:52 AM
bdlawnic's Avatar
Still.
Old Sep 29, 2013 | 12:37 PM
Originally Posted by bdlawnic
Still.
The tach gets its signal from the igniter (ICM). Either your igniter is dead, or there is a wiring problem that is preventing the igniter from operating.
Old Sep 30, 2013 | 07:47 AM
bdlawnic's Avatar
Replaced the igniter already.
So this morning the car runs and drives after I adjusted the timing last night.
HOWEVER there is a awful mechanical whirr-ing sound that occurs when I accelerate.
Ideas?
Old Sep 30, 2013 | 11:34 AM
How tight is the timing belt?
tegguy1987
17
Dec 17, 2018 12:58 AM
GiboGSR
Nov 24, 2017 07:53 AM
Cody Dressler
Jan 31, 2017 04:31 PM
DIZSTRICTxB3A5T
Mar 11, 2011 12:41 PM
DG Merrill
Dec 9, 2008 02:43 AM
