Questions on my ef with b18a1 ( transmission noise )
Ok so I was getting home parking and when I parked my car started making a honderous clacking noise. When I depress the clutch it goes away. Im guessing this is the throwout bearing. What I want to know is how this happens and what can I do to fix it? Before I drop the tranny can it be something like my clutch cable being to tight or something. My clutch engagment point is very close to the ground. I havent driven it but it still goes into gears etc..
It shouldn't be your cable, but your cable is easy to adjust if it is a cable actuated clutch. You just go to the trans, pull up on the clutch cable and tighten the black nut on the top a little. Then check where it now engages inside the car.
Markb16a
Nov 24, 2007 09:09 PM
