Eg electrical problem .help guys..
Old Sep 19, 2013 | 09:10 PM
Eduardo Coria's Avatar
Icon2 Eg electrical problem .help guys..
Ok so I swapped my hatch and got it running 👌
Now the problem is my cluster gauges don't work
No gas, temp, rpm nothing !
Also no turning signals. Does anyone know what can be causing
This problem that can help me?
Help appreciated ...
Old Sep 20, 2013 | 06:33 AM
fcm's Avatar
fcm
Old Fart
Default Re: Eg electrical problem .help guys..
By "I swapped my hatch" I assume you mean you did an engine swap, correct?
If the cluster and signals worked before the swap, and not now, my guess is you forgot to plug something in.
Eg is not a lot of help, what is the MM&Y of your car? 94
Old Sep 20, 2013 | 02:20 PM
No they didn't work before swap. It's a 93 civic hatchback
Old Sep 20, 2013 | 04:31 PM
HondaPartsHero's Avatar
Technical Hero
Check all under hood/dash fuses?
Old Sep 20, 2013 | 04:34 PM
Jesse R Bryant's Avatar
hey guys sorry i am not sure were to post my problem, I'm not trying to intrude. I have a 94 civic dx, new fuel pump, fuel filter, wires, plugs, alternator, battery. before i got the the new alternator as long as i got a jump the car would always start.... Now it will only start when it wants, I am dumb founded as to what the problem is, Once it does start it runs perfect, I don't know what else the prob could be, or what to troubleshoot now, Someone told me i may have a ground issue, Any input or suggestions appreciated, And again sorry if this is not were i should post this. Thank You
Old Sep 20, 2013 | 10:59 PM
I checked them and there all good bro I think ?
Which ones should I check?
Old Sep 21, 2013 | 02:04 AM
reg_lus's Avatar
Signal dont work- check FUSE or the Emergency Hazard switch is not plug, so check that also. OR you forgot to plug the harness to the cluster lol
Temperture- Check the sensor plug underneath the distributor like a pin
RPM- May be your distributor. Open up your distributor cap, there is 1 wire on the ignition module. That might not be hooked up or ICM might have went bad for that section. If it's not that, then it could be something else that I might not know? Bad cluster?
Old Sep 21, 2013 | 07:33 AM
fcm's Avatar
fcm
Old Fart
For the cluster it is fuse #10 -10A, [in under dash fuse box.
However, if the left head light works the fuse is good, you will have to pull the cluster and test the red/green lead in the cluster plug(s), it is the only red/green going to the cluster, it should show 12V+ when ign. switch is on.
If you have power at the red/green, [at cluster] check any/all black ground leads going too the cluster for continuity to chassis ground, [any ground point] if good, the problem is the cluster.
If no power at the red/green, [at cluster plug] check the red/green at the 20 pin plug on the under dash fuse box, [again with the ign. switch on] if there is power there, the problem is between the cluster and fuse box, [broken lead], if no power o the red/green at the 20 pin fuse box plug the problem is the fuse box or the plug, [unplug it and check for corroded/damaged pin/socket].
For the signal lights, question, do the hazard lights work?94
Old Sep 21, 2013 | 08:14 AM
Ok thank u all for the help. I will recheck everything u guys said,
My harness is connected though, when I took off the dashboard
There was a thin black wire loose , it was screwed on to the
Thing that moves the tires , (steering wheel area) so i don't know if that could be it?
bserieseg94
Feb 17, 2014 08:11 AM
n/aeghatch56
Dec 21, 2011 07:13 AM
da egg
Aug 2, 2009 09:25 PM
JDM*BUBBLE
Jun 6, 2004 10:42 PM
Spartanic
Jan 6, 2003 09:43 PM
