Starter Ground
Old Sep 18, 2013 | 10:57 PM
GoBrowns's Avatar
Default Starter Ground
I recently purchased a EG hatch that has been GSR swapped. Was having a starter issue and decided to replace it. The new starter did not come with a ground connection. Has anyone else seen this?
Old Sep 19, 2013 | 02:50 AM
Runnerdown's Avatar
Default Re: Starter Ground
The starter grounds through the casing which is bolted to the transmission. The large cable on the transmission itself then grounds that to the battery.
Maybe you are referring to the start signal wire with the spade terminal. That is required to actual trigger the starter. If the new one is missing that then bring it back and get another.
Old Sep 19, 2013 | 03:08 AM
Fliptard's Avatar
starter has 2 wires. one from the battery, and a small signal wire that has a flat prong. there should be a wire from the engine harness that connects to it
Old Sep 19, 2013 | 03:58 AM
GoBrowns's Avatar
Thanks for the replies.
When i removed the starter there was a bracket off the top of the starter with a ground coming off the chassis, which is where the battery ground is connected to. I figured this was normal. I'm finding tons of things that are apparently wrong. I will move the engine ground to where it should be.
Old Sep 19, 2013 | 04:04 AM
Fliptard's Avatar
that ground is correct, however, I removed the bracket to clean up my bay and placed it on a bolt on the transmission. I think I have it bolted to a bracket for my clutch line. As long as it's bolted and grounded to the transmission, your good to go.
Old Oct 3, 2013 | 02:56 AM
GoBrowns's Avatar
Forgot to say thanks. I rerouted the grounds and every thing is good.
hondachris1994
Aug 15, 2019 03:07 PM
hondachris1994
12
Nov 9, 2017 05:15 PM
HT Chaplain
Jul 28, 2009 05:33 PM
bayoufrogg
Oct 24, 2006 08:18 PM
GoodEyeSniper
17
Sep 8, 2006 11:31 PM
