Anyone ever have trouble installing LCAs?
I searched and found lots of issues removing the lower control arms, but installing them never seems to cause anyone grief. Except, apparently, me.
I'm doing a large overhaul of my Civic, including the LCA bushings. I replaced the torn stock bits with Prothane polyurethane bushings. Removed and replaced the LCA bushings myself using hand tools (fun...) and all I have to do is bolt them in. How hard can it be, right?
Well, the front bushings I can get in place (but I've pulled the LCAs back out to start with the rears), the rear bushings are extremely tight and no matter how I shove, pry, twist, etc they don't want to go in. The passenger side is farther in and I may be able to get it with some more manhandling, but the driver's side is a long ways off.
Any tips or tricks?
Any tips or tricks?
I've struggled a bit with mine but not quite to the extent you describe. Got any pics? BTW, have you tried loading the suspension with another jack?
I'll get some pics tonight when I work on it again.
Sorry, I should have been clearer. Meaning - have you tried to get it started, put on the ball joint, and THEN load the suspension. I'm not saying it's the right way to go and - to be honest - I didn't have to do this - I think I just beat mine like heck with a mallet and it popped right in. But here's how one guy did it. Just skip toward the end for the reinstall and it looks like he fought it quite a bit.
Personally, I like to STOP, take a deep breath, make sure I'm not dorking it up or haven't missed anything...then hit it like a pinata.
Well, first two pictures show where I stopped after the first day. Passenger side was close, driver's side was a long ways off.
Coming back at it on a new day with a whole lot of grease and vigorous application of the mini-sledge (with a block of wood) and success.
On a related note, I know there is supposed to be a plastic cover near the compliance bushing (I'm missing those), is there supposed to be one around the tie rod/steering rack too?
Good man! Nothing like a little sledge action to fix your car and take your frustrations away!
The only plastic cover I know of on the tie-rod/steering rack is the one in your last picture that sits around the passenger side of the steering rack. Everything else looked normal to me.
Jon Petersen
Dec 19, 2018 06:12 AM
Old91CivicGuy
Jun 18, 2001 01:55 PM
