stock feed as return ?
Old Sep 15, 2013 | 01:59 PM
boostlsveg's Avatar
Default stock feed as return ?
alright guys so im using my stock feed as return and my plan is to leave the banjo bolt and just cut off the tube that normally goes to the pump so the return just shoots straight down into the tank. so my ? is , is this what I should do or something else? also wondering what fitting I need to go into my hanger for my 8 an feed and also how do I connect said fitting to the pump? pump will b walbro 450. thanks for any help I can get guys.
Old Sep 15, 2013 | 02:33 PM
boostlsveg's Avatar
Default Re: stock feed as return ?
So im thinking I can get a full blown hanger feed fitting and drill a hole threw my hanger n put a nut on the bottom side n get a barb fitting to screw in the feed fitting for the hose to go on from the pump. U guys think this would work?
Old Sep 15, 2013 | 04:41 PM
boostlsveg's Avatar
http://www.jegs.com/images/photos/50...555-110846.jpg
http://www.jegs.com/images/photos/200/259/259-98105.jpg
http://www.jegs.com/images/photos/30...1-AT982208.jpg
something like this the second one and third one together or the first one with the full blown fitting
Old Sep 15, 2013 | 06:51 PM
boostlsveg's Avatar
well I was hoping for some insight but I just went ahead and ordered the 90 degree 8an to 3/8 npt and the 3/8 npt female barb to 3/8 hose hopefully that will work
Old Sep 16, 2013 | 06:44 PM
boostlsveg's Avatar
no ideas guys
B_Swapped93
May 15, 2017 03:33 PM
danedoremus
Welding / Fabrication
21
Nov 7, 2011 11:58 AM
92redhatch
Dec 29, 2008 06:13 PM
Unsivil_audio
May 5, 2008 07:41 AM
paulzy
Oct 22, 2002 03:35 PM
