how do you install a walbro inline pump?
are you using 2 or just the external, asking because iirc doesnt it flo just as muvh as the intank?
and you can use the stock feed as a return, it suits my weldon just fine.
Guest
Posts: n/a
You put it inline...as in somewhere from the tank, to the rail. You can run a new line from the sender if you had a fitting welded to where the barb comes out for the feed, or cut the stock line and clamp some hose down.
The stock return is fine for you, I'd run a new line for the feed however. 3/8 line would be good for it.
you can put it after the fuel filter to the inline pump then to the rail, I seen that done a few times. Thats if your still using stock lines and don't want to cut up the hard lines.
I mounted my inline behind the gas tank towards the rear bumper and then ran the feed to the rail. Your stock feed will be just fine as the return, its -6 in size. Make sure you wire both pumps with relays and power them from the Alt or Battery. You can use barb fittings or AN fittings, I think the thread on the inline is something wierd like 10mm, I had to buy the special adaptors to -6 AN and then run -6 to -8 increasers on both sides of the pump.
If I was to do it again I would of just ran my intank 255 to a Bosch 044.
i found this on google about the inline between the filter and the rail
http://images.google.com/imgres?imgu...en-us%26sa%3DN
danedoremus
Welding / Fabrication
21
Nov 7, 2011 11:58 AM
