d16y5 rebuild help
Old Sep 14, 2013 | 11:03 PM
94Preludedude's Avatar
Default d16y5 rebuild help
I am doing a complete head rebuild and need to know what parts to get full overhaul with a phew upgrades have a 1500 limit plzplz help
Old Sep 15, 2013 | 01:18 AM
J-RAD's Avatar
Default Re: d16y5 rebuild help
woah. $1500 to spend on a D16 head?
jbpnoman's Avatar
I guess picking up a factory service manual was out of the question? If you're asking this basic of a question, you NEED to buy yourself an FSM.
Absolute raw basics: Water pump, timing belt, tensioner, head gasket, valve cover gasket, spark plug grommets, valve stem seals, intake manifold gasket, exhaust manifold gasket. You'll also need a tube of HondaBond, as well as a tube of assembly lube.
Seriously, buy/borrow/download a factory service manual. It will make your life a LOT easier, and includes detailed pictures, torque specs of every bolt, as well as a list of tools at the beginning of the engine overhaul chapter that you'll need for the job.
Old Sep 15, 2013 | 03:51 AM
I know the basics just wondering if anyone new some ok upgrades to go with
Old Sep 15, 2013 | 03:54 AM
Also grabing a chiltons before I start wrenching. Im an ok tech just havent done head build before this is my first sohc build
Old Sep 15, 2013 | 04:31 AM
jbpnoman's Avatar
You have a Y5. It's the most econo of all of the econoboxes for our generations. There are absolutely zero "upgrades" worthwhile.
Old Sep 15, 2013 | 04:47 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Not worth any performance mods. Either rebuild it stock or get a different head.
Old Sep 15, 2013 | 06:45 AM
TripleLude's Avatar
The Chiltons and Haynes are $20 paper weights. Literally, I use them as paper weights to keep the FSM print-outs from blowing away. Never trust the torque specs in Chiltons or Haynes.
And yea, don't forget to prime the oil before first startup, and the break-in procedure.
ujhonda
Jul 4, 2007 07:55 PM
92integraVTECgsr
Feb 19, 2005 05:52 PM
trigun7469
Sep 6, 2004 11:12 AM
dohc-nyne
Apr 22, 2003 03:15 PM
bigmike
Apr 10, 2003 11:13 PM
