Suspension troubles!?!?!?!
ive got a 98 civic dx. I already know that I messed up so please don't tell me how worth the money it is because ive seen by example and been told time and time again, I just need help with my problem. i put a shitty ebay lowering kit on my car and it was making my car sit on the tires. i switched back to stock and my car is practically sitting on the ground. ive tried different size tires and adjusting and tightening everything i can think of (cambers, control arms, etc.) any ideas why my car wont sit at a drivable ride height anymore? open to any suggestion, im getting desperate!!!
Front or Rear? Did you tighten the pinch bolts on the front spindle forks?
If you dont it will slide up on the shock.
Are you using stock springs?
More info please.
pics dont hurt.
More info please.
pics dont hurt.
If shocks were blown even after putting stock setup back on car should not be sitting on the tires. Sounds like something didn't get bolted back on correctly.
Sounds to me like you only put the stock shocks back on as mentioned. No way you should be lowered like you describe if it was 100% stock.
When installing the ebay kit, were any stock parts modified and re-utilized?
