1998 Accord intermittent power window.
Old Sep 12, 2013 | 02:22 PM
albion01's Avatar
Icon2 1998 Accord intermittent power window.
I have a 98 accord with a bad driver door power window. The driver window switch intermittently stops workings. Sometimes if I hit the on off switch it'll start. Sometimes if I hit the door panel it will start working. Sometimes it just starts working on it's own. It'll usually works for a little while then stop working again. All other windows work perfect from all interior control panels.
Any ideas? Bad switch? If so do I have to replace the entire driver door control panel.
-Craig
Old Sep 13, 2013 | 08:34 AM
Lost Again's Avatar
Default Re: 1998 Accord intermittent power window.
Sound like a bad or dirty switch. Remove the master switch and try cleaning the contacts. While there you can test for continuity on the pins to see if it is making the proper contact.
aresjay
Oct 17, 2018 01:36 PM
pre90
Jun 9, 2015 10:22 AM
hondagal2004
Nov 27, 2013 07:55 PM
blackccoupe
Oct 5, 2012 07:40 PM
ridenslide65
Sep 28, 2008 07:29 PM
