No power to fuel pump, no spark and will not scan
Old Sep 12, 2013 | 03:10 AM
mike5ive's Avatar
Default No power to fuel pump, no spark and will not scan
2000 civic
What's up with this dam rice burner, No power going to the fuel pump, power going to the distributor but no spark from the coil ( Igniter is good, coil is good ) and scan tool cannot comunicate with the computer. Note: My brother has the exact same model and year and scan tool has no problem reading his
Thank you for your consideration
Every week I'll spend money on my car, women and beer and the rest I'll just waste
Old Sep 12, 2013 | 03:29 AM
jbpnoman's Avatar
Default Re: No power to fuel pump, no spark and will not scan
When you turn the key to ON(II), do you hear the main relay click? Does your CEL come on for ~2 seconds, then turn off?
Old Sep 16, 2013 | 06:11 PM
mike5ive's Avatar
cel light stays on, so far i have changed main relay, no luck with that. I'm begging to think that the metal this car is made from is cursed
Old Sep 17, 2013 | 03:59 AM
jbpnoman's Avatar
Saying you changed it doesn't answer the question. Do you hear it click?
Old Sep 17, 2013 | 04:11 AM
94EG8's Avatar
Seagull Management
Did you check the thermostat ground?
Old Sep 17, 2013 | 01:11 PM
Former User's Avatar
This^
And also check fuses 44 and 13.
Old Sep 24, 2013 | 01:30 PM
mike5ive's Avatar
The fuses are good, cleaned and sanded connections on the thermostat housing and no i hear no clicking when i turn the key. Thank you all for your consideration.
The difference between an idiot and a genius is that genius has a limit
Albert Einstein (circa) 1934
Old Sep 24, 2013 | 01:33 PM
Originally Posted by mike5ive
The fuses are good
How did you determine this^? Give details. Post pictures of the two fuses that you tested.
Does the starter crank the engine in ON(III)/START?
Old Sep 24, 2013 | 01:49 PM
94EG8's Avatar
Seagull Management
That being the case try a known good ECU/PCM. They don't fail often but when they do they will act like that.
Old Sep 25, 2013 | 03:17 AM
mike5ive's Avatar
Yes the engine turns over with the key, the spark igniter tested ok at auto zone, coil is good ( replaced it with one from a car that runs ) The distributor is getting power but i get no spark to the plugs or with cap off out of coil to a ground. Fuel pump works is you apply 12vdc to its ***, no power going to it when key is on / running position. Fuses are good, replaced them anyway. PGMFI relay is good / \ switched one out from a running vehicle and it will not scan /it reads no communication or something along that line. I added a ground to one of the terminals on the pgmfi relay and the fuel pump will now run with the key in the running position but i don't think it's the safest way to do things // it will just keep running with the motor not turning over ( no doubt )
Ever notice that all the scientific instruments which are searching for intelligent life are all pointed away from earth
Old Sep 25, 2013 | 04:44 AM
Where did you add the ground wire to the main relay plug? Post pictures or describe, and then remove it, if you haven't already.
At the unplugged main relay plug, test whether battery voltage reaches the terminals from fuses 13 and 44. There's multiple electrical tests to do there and at the ECU plugs.
Old Sep 29, 2013 | 01:08 AM
mike5ive's Avatar
added the / a ground to the green wire with the yellow line running along it. yes i removed it.
My nephew's model civic has the same pgmfi relay and i have switched them and his civic is working fine with the one that came out of this one.
Since the pgmfi relay only controls the fuel injection and the fuel pump ( I'm thinking? ) and i am also getting no spark / even though the spark igniter, pickup coil, coil rotor and rotor cap are all good ( as i have switched the entire distributor with my nephews and again his is running fine ) and there is 12vdc going to the distributor from the wiring harness plug / possibly the pgmfi and the distributor share a common ground that if f-ed up somewhere in the wiring harness. Do they share a common ground???? And yes i have both sanded the connection area on the thermostat housing and cleaned , heated, fluxed, tinned and added solder to all the ground wires at their crimped connection ends at that thermostat housing
Will test for battery voltage @ 13 and 44 in the morning but again since the fuel pump will run when the key is in running position and the pgmfi relay is connceted ( that is if i add a ground to that green and yellow lined wire ) #13 or #44 whichever.....must be feeding the relay 12+.
No spark, no fuel pump ground and no communication the the scanner when trying to scan. It's sounding more and more like that ECU has gone south,,,,No?
brian91accord
Aug 25, 2011 04:18 PM
90turbointegra
Sep 2, 2009 03:41 PM
520_Motorsports
Jan 20, 2008 12:21 PM
david542
30
Jul 20, 2007 03:41 PM
Hadude
Nov 16, 2003 09:18 AM
