A/c problems. low side pressure in vaccum.
Old Sep 11, 2013 | 03:07 PM
EgHatchy96's Avatar
Default A/c problems. low side pressure in vaccum.
Okay, so I'm having a problem with my Dad's A/C on his 95 Sedan. It's a D15B7 & I've evacuated, vaccumed, leak tested, & recharged the system all over again twice with the recover all in one machines that I have access to. I just replaced the Compressor & the Reciever Drier. Put required amount of oil in everything, clutch kicks in & A/C is charged up to spec with 1.4 LBs. The problem is that it's not cold at all until about past 4.5K RPM. I put the guages on both High Side & Low Side, & I'm getting 140 on my high, & my low is going so low that it goes past zero into vacuum with the compressor clutch kicked on. I asked a friend, & he said that it could be the expansion valve not functioning properly, but I prefer more input before I replace it..
Old Sep 11, 2013 | 03:15 PM
EgHatchy96's Avatar
Default Re: A/c problems. low side pressure in vaccum.
Forgot to say it passed a leak test too.
Sinner
Aug 9, 2022 06:27 PM
kct01
Acura TL, RL & ZDX
Jun 6, 2013 06:45 PM
john85020
Honda CR-V & Element
Jun 27, 2012 09:09 PM
einzelherz
Aug 28, 2008 04:19 AM
Fastrax203
Jul 27, 2005 06:27 AM
