Compression test on b16a2
Old Sep 11, 2013 | 02:52 AM
B16.vtec's Avatar
Default Compression test on b16a2
Done a compression test on my b16a2 engine.
Cylinder 1: 180 psi
Cylinder 2: 181 psi
Cylinder 3: 182 psi
Cylinder 4: 153 psi
Is cylinder 4 ok to be that low?
Was done when engine was warm!
Then put a few drops of oil in the cylinder 4 and done it again, it went up to 180 psi.
Old Sep 11, 2013 | 06:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: Compression test on b16a2
Cylinder 4 is not OK, it needs rings, may just be a stuck compression ring, but if your pulling the head/oil pan to check that one piston, you may as well do a ring job. 94
Old Sep 11, 2013 | 07:06 AM
B16.vtec's Avatar
ok thanks for that info!!!!
Old Sep 11, 2013 | 09:00 AM
B16.vtec's Avatar
Would it be hard to put in rings in one these engines?
Old Sep 11, 2013 | 10:13 AM
grumblemarc's Avatar
The Grumpiest
If you have to ask, then it's too hard for you. Download the Field Service Manual or research the procedure.
Old Sep 12, 2013 | 01:33 AM
holmesnmanny's Avatar
You should do a leakdown test to see if the issue is the headgasket. It's normally cylinder 4 that goes when the headgasket starts to leak.
Old Sep 12, 2013 | 04:09 AM
B16.vtec's Avatar
Would the 153 psi on cylinder 4 not wait the same after puting a few drops of oil in if it was the headgasket leaking?
Old Sep 12, 2013 | 06:04 AM
lol i didn't see that the first time around..nevermind my post
Old Sep 12, 2013 | 06:08 AM
fcm's Avatar
fcm
Old Fart
Yes, the oil points directly to the rings, either way you will be replacing the HG.
How hard is it to do rings on that engine, for me it is a walk in the park, for you will depend on your skill level and the tools you have. 94
Old Sep 12, 2013 | 06:58 AM
B16.vtec's Avatar
Thanks anyways holmesnmanny!
Yes i was researching it and it seems easy enough.... so im going to give it a try....
I have most of the tools as i done alot of jobs with other cars before!
stir_fry_boy
May 15, 2018 06:27 AM
delsolo95
Apr 3, 2013 08:49 AM
aznxpyroboi
Dec 9, 2007 10:09 PM
Tyteg
May 16, 2007 07:30 AM
