Help! Car overheat
Hi there so yesterday i drove to school and suddenly i notice it came out smoke on the radiator so i got the fan switch thermostat radiator change but i notice my fan is not coming on. I try replace fan switch/paperclip in pin that made it run but the thing is when i plug it in the fan switch it not working. So what am i doing wrong over here
if someone can help me that would be great and thank you!
He already said it tuns with the connector jumpered (that what I translated from the broken English). Wiring it directly to the battery won't tell him anything new. Did you try the simple things like replacing the radiator cap or thermostat? Did it overheat?
i would wire it manually but my family use it so i don't want to get it overheat. im just wondering what wrong with it or is there no solution at all to fix this? i thought replacing the fan switch help but it still the same thing. i pull out the relay when i put the paperclip on the pin and it turn off when i take the relay out so yeah im running out of idea.
alpinegroove
Oct 22, 2013 10:27 AM
phoxking
Apr 10, 2011 02:05 PM
