98 Rear Strut Job - Broken Bolt (Safe to drive?)
Old Sep 9, 2013 | 08:47 AM
dorian7's Avatar
Default 98 Rear Strut Job - Broken Bolt (Safe to drive?)
Hi All,
I was putting on some new struts this weekend and the front was a breeze. Then came the back... I managed to snap this bolt off. About 2/3-3/4 of the bolt is left inside. The car sits fine on it for now. My question is that do you think it is safe to drive it a couple miles to the mechanic to get it fixed?
Old Sep 9, 2013 | 08:55 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: 98 Rear Strut Job - Broken Bolt (Safe to drive?)
I would guess no, but maybe someone else can comment.
Old Sep 9, 2013 | 08:58 AM
B_Swapped93's Avatar
If break is after the bolt that's welded onto the shock in other words there's no threading on the part of the bolt that's broken of then I wouldn't seeing as there wouldn't be anything holding it in. safe to drive to a shop...sure just be careful or just get a used shock and go from there then you can bypass the need for a shop
Old Sep 9, 2013 | 09:02 AM
SlowSOHC-T's Avatar
I've done the same and if you just snapped the head off the bolt, you should be fine as B_swapped said just be safe and drive SLOW!
Do you have a picture of the break?
Old Sep 9, 2013 | 11:35 AM
dorian7's Avatar
Thanks for the feed back everyone. The head of the bolt snapped so it is still fully threaded and has about 2/3 left still in there.
KKRIS
27
Feb 28, 2012 09:21 AM
Si_chRis
14
May 27, 2007 09:05 AM
boostin4drcivic
Apr 18, 2004 03:57 PM
IWearMyKswiss
Mar 15, 2004 05:16 AM
Matt B
Apr 20, 2003 07:12 PM
