Honda Accord 97 V4 cigarette lighter outlet not working
So I've noticed that the cars outlet does not work, I did some research and found that it might be a fuse, but my question is how do I check the fuse, like where is it located? I know it's that cause I've plugged a few chargers and none of them work
There is no such thing as a v4.
Some people actually disconnect the power wire to the cigarette lighter. If you can take out the radio and physically confirm that the power wire is actually attached to the lighter that would be your first thing to check.
Fuse should be #11 (10 amp) in the drivers under dash fuse box. If you have the factory radio, that same fuse "feeds" the radio as well....so if the radio (factory set up) is working then the fuse is fine.
From there, "holmes" has already answered the question.
To access the cigarette lighter wiring and relay, the console needs to be removed; however, the radio does not necessarily need to be removed.
Sir, it could be the bad manual I have but doesn't the radio also "feed" off the "lighter relay"?
So, in conclusion, if the stock stereo works, both fuse 36 and 11 should be okay. Therefore, if stock stereo works, it probably comes down to the wiring or lighter socket.
my box does not say anything with cigarette lighter, just radio motor antenna and heater, it has other things but I don't think is related to what I'm looking for
you could pull and check every fuse if your stumped. If it isn't a fuse I'd check the leads to the lighter as previously mentioned. It will require a good amount of time though.
[IMG]www.dropbox.com/sc/0zz46b9gfzuk02d/xu-7YDHpGL[/IMG]
i got these two but i dont know which one is the fuse for the cigarette lighter, help ?
jwinthrop
Dec 31, 2012 05:27 AM
Stover954rr
Audio / Security / Video
Jul 31, 2012 03:09 PM
boostedefhatch
Jul 10, 2009 12:15 PM
