Gsr knock sensor cel quick help
Swappers help. I just want a clean dash. I have a 1996 Gsr in an ek4 with a stock harness wired for VTec etc.
I pulling code 23. Is there a plug on the harness or I gotta re pin the ecu ? Not sure. Or is there a way the jumper it out so the stock (USDm Gsr ecu I believe) won't see it?
Emissions can't have codes here also so I'm preparing
I did search but so many variables anyone who knows pls
Post
Post
If you loved me, you'd all sell me your magic cards to me today
is it really an EK4 or is this a USDM car? What is the block number on the GSR, is it USDM or JDM? Which harness are you using, the one that came with the car? What ECU are you using? Where are you doing emissions? Is there a knock sensor in your block? Is it plugged into the harness? If not into the harness have you wired it into the ECU?
Maybe this helps if you need to wire it yourself.
I believe a p72 currently obd2a and usdm
My other q will this AFfect performance for racing I have code 1 and 23. And am re checking timing marks / ign timing to top performance. Code 1 I have spare o2's if that's what's needed
ultima4300
Jul 20, 2010 05:06 AM
wonder1and
Feb 23, 2005 08:21 PM
