Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16 trans with ctr LSD problem?
Old Sep 5, 2013 | 08:18 PM
DelSol-B18's Avatar
Default B16 trans with ctr LSD problem?
Just bought a b16 trans with ctr LSD. Is the diff suposse to move side to side?? If you put your hand on one side of the diff and your other hand on the other side you can move it back and forth. Is this normal?!
Old Sep 6, 2013 | 12:04 AM
B(eighteen)C's Avatar
Default Re: B16 trans with ctr LSD problem?
with or without the gears on? completely disassembled with diff only? have you done a bearing inspection, look ok?
Old Sep 6, 2013 | 04:59 AM
DelSol-B18's Avatar
The trans is all assembled ready to go in. I've never dealt with anything inside a transmission
Old Sep 6, 2013 | 06:11 AM
kyden's Avatar
it's not supposed to have play.
Old Sep 6, 2013 | 06:30 AM
DelSol-B18's Avatar
****!!!! Alright well thanks for bad news lol
Old Sep 9, 2013 | 09:55 AM
parts@synchrotech's Avatar
They may have installed the incorrect bearings on the LSD and/or not have set the preload correctly.
Get it open and check what bearings have been installed and what shim was used. If it was installed using B16 bearings..here is what you will need to fix it:
It will need two offset bearings for ITR/CTR/Late model GSR differentials:
http://shop.synchrotech-transmission...GSR-B-ITRB.htm
or you can also use a Conversion kit to save some $$:
http://shop.synchrotech-transmission...-GSR-BITRC.htm
The difference between a B16 diff bearing and ITR/CTR/Late model GSR diff bearing is a 1mm offset on the center inner diameter where it mounts onto the bearing spigot.
RPRacing
Nov 14, 2005 12:27 PM
ZERO COOL
Feb 5, 2003 10:39 AM
ZERO COOL
Jan 27, 2003 12:58 PM
ZERO COOL
Jan 21, 2003 03:55 PM
