Help car won't start (rebuilt motor)
Old Sep 3, 2013 | 04:58 PM
1POS_CRX's Avatar
Default Help car won't start (rebuilt motor)
So I rebuilt my d15 due to the valves and rings finally giving out and smoking like a chimney. Everything is back on and in the car but can't seem to get the motor to fire. I took my sweet *** time rebuilding this thing so possibly some sensors could have gone bad, but I'm kinda lost.
There is a lot of fuel and spark going into the motor and timing and firing order of the wires seem to be correct so what gives? The starter is working perfectly fine as the motor is turning over but not firing. What does happen on occasion is that the motor will back fire through the intake manifold (I know not good lol). Can anyone point me into the right direction? Thanks in advance for all the input.
-Jon
Old Sep 3, 2013 | 05:02 PM
1POS_CRX's Avatar
Default Re: Help car won't start (rebuilt motor)
Also ECU Code #10 is being thrown. Before the rebuild the car was throwing this code but still ran fine. I did switch up the plugs for the Intake Air Temperature Sensor and Electronic Air Control Valve per suggestion on this thread https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/1991-crx-d15b-ecu-code-10-14-a-2843993/ but still no go.
-Jon
Old Sep 4, 2013 | 05:43 AM
crxin's Avatar
if you have fuel and spark and your timing is dead on the car should start, unless you have no compression. Have you done a compression check? Did you do the rebuild yourself? Is it possible that one of the rings moved and the gaps are lining up and not building compressing? Just a couple of thoughts.
Old Sep 4, 2013 | 08:12 AM
Mr20v's Avatar
U got all your grounds hooked up
Old Sep 7, 2013 | 09:57 AM
1POS_CRX's Avatar
Did a compression test and it has between 150-155 in the 4 cylinders. I have a feeling this is on the low side but the rings haven't had time to seat, so would these numbers be okay?
Going to be rechecking the grounds this weekend and will report back. Thanks for you guy's help so far.
-Jon
Old Sep 7, 2013 | 09:59 AM
1POS_CRX's Avatar
Timing looks right, but if it's back firing through the intake manifold the timing can't be correct can it? I've worked on way more complex motors and this little guy has me stumped lol
-Jon
Old Sep 7, 2013 | 10:01 AM
rd91sib18c5r's Avatar
Either the distributor is 180 out or the timing is off.
Old Sep 7, 2013 | 05:16 PM
lsdisk0's Avatar
either dizzy is 180 and/or you have the IAT and EACV harnesses backwards.
green plug to EACV "white" to IAT.
lajoyce357
May 31, 2017 09:03 AM
dkillahster
Sep 10, 2010 12:26 PM
kaluwa3
Dec 7, 2008 01:33 PM
clemsoncb7
Jun 11, 2006 12:21 PM
[626]95-GSR
May 15, 2002 03:22 AM
