1996 gauge cluster pinout needed
I have a 1996 accord coupe ex I am trying to get a pinout for. The cluster stopped working (sometimes starts working intermittently) after checking and replacing all the fuses we tried a replacement cluster with no success. We have decided it is probably a harness issue but cannot locate a wring diagram for 1996 and the wire colors are not consistent between year models. We did figure out which was ground and we have continuity. Any other suggestions?
Thanks
Thanks
It started with the speedo and tach then the heat and gas gauge failed too. The cluster will magically all start working then hit and bump and all gone again. Right now nothing works. Tried a new cluster and nothing. The ground seems to be the black/yellow and it works. There are 2 yellow/silver wires on the largest connector and one has continuity and the other does not seem too. The gauges would flicker in the past and but we believe something may have shorted when a sub possibly blew some fuses. All fuses in car and under hood have been checked and replaced, even working ones. Also swapped relays and made sure all were working under hood.
Thanks
Thanks
STPREZ
Jan 15, 2005 02:42 PM
