***Fully Built Turbo Engine B16a3 Made Over 500Hp Great SHAPE!!!!**
Old Sep 2, 2013 | 08:36 AM
b20vdelsol619's Avatar
Default ***Fully Built Turbo Engine B16a3 Made Over 500Hp Great SHAPE!!!!**
Top to Bottom Build on a B16A3 is up for sale. It was compression tested before pulled out in perfect working order. no problems what so ever.
Engine Specs:
B16A3 Bottom End;
Cleaned, Inspected/Measured, Honed & Assembled by Hopsing Machine in San Diego (never has been decked)
JE Pistons 9:1 Compression
Eagle Rods w/ ARP Rod Bolts
ACL Race Bearings , Main, Rod, Thrust
NEW Type R Oil & Water Pump.
Fel-Pro Head Gasket
Rising Sun Timing Belt(new)
Upper End(head)
ARP HeadStuds Torqued to 70ft/lbs 3-step
Stock Port
Skunk2 Titanium Valve Springs
Skunk2 Tinanum Retainers
Skunk2 Tuner Stage 1 Cams
Skunk2 Cam Gears
Head was cleaned, resurfaced and knew valve guides, knurl's, and valves for a perfect seal.
Skunk2 Intake Manifold
BWR ThrottleBody
I guarantee this is in good running shape, no knocks, no noises, Solid Compression
2200$ or trade for running cars of same value. 619-633-6139 Located In San Diego (92071)
Old Sep 2, 2013 | 08:40 AM
Default Re: ***Fully Built Turbo Engine B16a3 Made Over 500Hp Great SHAPE!!!!**
This is the engine you will be purchasing.
Old Sep 3, 2013 | 12:23 PM
BUMP
Old Sep 3, 2013 | 05:33 PM
bump
Old Sep 3, 2013 | 05:59 PM
WILL TRADE FOR JET SKIES
Old Sep 3, 2013 | 06:52 PM
beho's Avatar
nice motor!
Old Sep 4, 2013 | 02:18 AM
Marvin1985's Avatar
Your camera guy sucks. Nice motor
Old Sep 4, 2013 | 08:28 AM
Trurazaflo's Avatar
Hands down one of the most interesting vids. Bump to a beasty motor. Glws
Old Sep 5, 2013 | 09:05 AM
Thanks for the replys. Still for sale.
Old Sep 17, 2013 | 06:18 AM
BUMP FOR SALE!
SunnyF23Vtec
Aug 22, 2015 12:52 PM
ChrisEK9
13
Mar 10, 2010 10:54 AM
ChrisEK9
Mar 7, 2010 12:32 PM
yakuza
Jun 4, 2008 02:32 PM
