zero oil pressure at idle
Old Aug 30, 2013 | 09:42 PM
raverx3m's Avatar
Default zero oil pressure at idle
yesterday I was driving home from a long test drive after I put the head back on
everything was good until about 3 blocks from my house
before I left I checked the oil it was at the top dot.
had a small oil leak from cam seals
about 80-100 mile drive everything seemed ok
3 blocks from my house the oil light started flickering and then turned soild
I didn't have the gauge hooked up yet after rebuild
got home parked the car and checked oil it was at lower dot
put about half a quart and it was at the top dot again I though it was kinda strange.
hooked up the oil pressure gauge today and it shows 20psi when cold and quickly drops to zero once rpm reaches idle speed(900rpm)
the gauge shows zero psi
but the oil light doesn't come on ( just randomly flashes once in a while)
I look through the oil filler hole and I can see the oil squirting out of the camshaft rails.
and the head is not dry
changed out the cam seals today and resealed them
stared the car same thing
cams and valvetrain don't have any scoring on it I checked just now.
oil pump is brand new oem Honda installed 10000 miles ago. never had dropped pressure until yesterday never ran low before yesterday also.
service manual doesn't say anything about it
and I couldn't find any solid answer here or goggle.
car doesn't smoke during normal driving or hitting vtec. only smoke I saw is when I decelerate for long time like going down a long hill which is also new never happened before.
head had valve guides reconditioned and valve seats cut new valve seals and new cams and resurface.
I did notice a light cross pattern on my cam journals tho do machine shops do that a lot?
Old Aug 30, 2013 | 10:12 PM
raverx3m's Avatar
Default Re: zero oil pressure at idle
can the oil pressure be measured in the block and the head separately
theres an oil orifice in the block
the back of the block measures pressure before it goes to head
the bolt on the front of the head measures the pressure when vtec is engaged
can I connect the oil pressure gauge where the vtec pressure switch is to see if the camshaft clearance is too much after installing new cams?
Old Aug 31, 2013 | 02:00 AM
1HGEJ2's Avatar
put the oil pan down and check the oil pickup
Old Aug 31, 2013 | 02:15 AM
holmesnmanny's Avatar
don't you need to remove the oil orifices for vtec engines ?
Old Aug 31, 2013 | 07:17 AM
raverx3m's Avatar
why remove those?
Old Aug 31, 2013 | 08:39 PM
raverx3m's Avatar
on cold start oil pressure starts off at 20 psi
then slowly drops to about 12psi
at 1100rpm it is at 10 psi
then as rpm drop very slightly the oil pressure drops to about 5psi
then I hear another slight drop in rpm and pressure drops to about 2 psi then slowly to zero.
although I can see oil dripping from cam rails and theres oil in the head
dropped the pan and found some surprise in oil pickup
first: the rod bearings do not move up and down at all. they move side to side just very slightly im assuming they should have clearance on the sides
neither rod ends or mains are discolored I didn't see any sign of overheating anywhere at all
the magnetic drain bolt picked up some grey colored goop (paste) that is magnetic obviously
but even under magnifying glass I cant see any metal flakes in it or metal shavings
cleaned it off and put the drain plug back in and it picked up even more of that goop
I haven't got to taking the oil pump off yet but im assuming I will find more surprises there also
here are the pictures I took
please help me decode them as I don't know what to look for exactly
machine shop work:
bronze valve guides were installed valves and valve seals were cut head was decked
they also for whatever reason sanded my cam journals I saw cross pattern that wasn't there before.
grey goop that was on the magnetic pickup
whats left after wiping
inside the oil pump
oil pan with leftover oil grey color flakes and when I mix it copper/bronze flakes show up
another oil pan angle
more goop on magnetic pickup
what I found in the oil pickup
more garbage in oil pickup
oil drained
Old Aug 31, 2013 | 08:53 PM
raverx3m's Avatar
oil pickup has good clearance to oil pan
I replaced the oil pan gasket not too long ago didn't find anything in oil or oil pickup it was completely clean and maybe few speckles of grey goop on the magnetic pickup
second oil change also didn't have any sparkles in it
since the engine was powered up first time the oil pressure was solid never changed until now
Old Sep 1, 2013 | 01:11 AM
Originally Posted by raverx3m
why remove those?
I thought you had to remove them from vtec heads and blocks in order for the oil pressure to get to the solenoid to get vtec to actuate.
Old Sep 1, 2013 | 08:01 AM
raverx3m's Avatar
Bump anyone? Not sure what the problem is
Old Sep 1, 2013 | 09:08 PM
raverx3m's Avatar
anyone have a picture of worn out oil pump innards?
mine doesn't look like its beendamaged in any way the inside of the gears looks like cast aluminum is it supposed to be smooth?
Old Sep 1, 2013 | 10:06 PM
raverx3m's Avatar
possible that stuck oil jet(s) would cause the symptoms above?
I took out one of the oil jets and found a decent size metal flake in it steel not bronze or copper.
will check other ones later
oil pump looks pretty worn out like something got stuck in it and grinded the *** out of it.
relief valve
gears outside
gears inside
pump housing
Old Sep 1, 2013 | 10:16 PM
KevinEF7's Avatar
Something was definetely in there and messed up those surfaces on the OD of the outer gear, they are definetely smooth from Honda
Old Sep 1, 2013 | 10:21 PM
raverx3m's Avatar
fn machine shop. wtf. there was nothing in the oil before I took the head off and took it to machine shop
now theres whole bunch of **** floating and stuck everywhere
the oil pressure was good. oil was clean with no flakes and oil pickup had maybe 3 -4 pieces of greygasket sealer and some wrinkle red particles from painting the valve cover
now its filled with ****. what can I do now can I go back to machine shop?( which im assuming will be hard to prove that they didn't clean the machining leftovers very well)
I have a feeling that the metal is everywhere now since it made its way into one of the oil jets.
theres metal flakes in vtec solenoid filter as well. when it was completely clean before
Old Sep 2, 2013 | 01:36 AM
1HGEJ2's Avatar
check ur camshaft too. maybe it has some scratches
Old Sep 2, 2013 | 04:59 AM
BeingCivic's Avatar
Looks like main or rod bearing debris. If the bearing goes completely you have metal to metal contact and that will cause the bigger chunks. Also if a camshaft lobe gets rounded off it will cause the same silver debris and large chunks of metal you see here. If all the cam lobes are smooth and not rounded off its prolly a rod or main bearing.
Old Sep 2, 2013 | 06:10 AM
IN VTEC's Avatar
The glittery gold/bronze flakes are indicators that the bearings are damaged. I'd have a look whether the main, rod, or both have been damaged. It may tell you where to look next for the cause.
Damage to the oil pump suggests that the problem occurred upstream of it.
Old Sep 2, 2013 | 10:25 AM
raverx3m's Avatar
theres nothing in the head now im wondering how the shavings got to the vtec solenoid
if the oil pump blew up wouldn't oil filter stop all the metal shavings?
cams look good rocker pads also.
Old Sep 2, 2013 | 11:17 AM
BeingCivic's Avatar
That silvery bronzey metal paste is worn bearing material. And the drop in oil pressure is the bad pump and prolly bad main bearings.
If the machine shop didn't clean all of the shavings out of the head some of that could have gotten in the pump and caused it to fail and thus the main and rod bearings to follow. It happened to my 79 z28 383 build. Shop built me a new engine for the mistake.
Old Sep 2, 2013 | 12:45 PM
raverx3m's Avatar
Damn is this worth spending money on or should i just find a c5 bottom end?
Im guessing the pistin rings and cylinder wals are also done from the metal shavings everywhere.
Old Sep 2, 2013 | 09:09 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
QFT.
At this point a new bottom end is probably the better option.
Old Sep 2, 2013 | 09:32 PM
raverx3m's Avatar
race car is expensive lol
I guess the kid is gonna have to eat less food for few years kidding
Old Sep 2, 2013 | 11:27 PM
Sounds like oil control jet oring is not installed causing excess oil pressure in the head and the bottom end lost pressure resulting in damage in bottom end and the oil pump got scored by those bits and pieces.
Just a guess tho.
Old Sep 3, 2013 | 06:34 AM
raverx3m's Avatar
Its there. I always check that one
Old Sep 3, 2013 | 08:13 AM
SiRCiviC94's Avatar
Good tech! Sorry to hear tho
Old Sep 3, 2013 | 09:38 AM
raverx3m's Avatar
Where would be a good place to buy a jdm itr bottom end?
I know hmotors sells complete biut i never seen them sell bottom end
negusjuda
Jun 21, 2011 12:57 PM
laziebun
Apr 24, 2008 11:36 AM
LostCRX
Jun 21, 2005 07:12 PM
TurboCX
Aug 3, 2003 06:33 PM
DuNkiN
Feb 22, 2002 05:50 AM
