Cylinder 3 misfire
Old Aug 30, 2013 | 02:06 PM
ArsenMotorsport's Avatar
Default Cylinder 3 misfire
Ok so found one thread that had similar symptoms but I have a b20 vtec, I bought everything brand new distributor, plugs, wires, new injectors, new fuel rail, and still only cylinder 3 misses changed injectors from 3rd to 2nd still only the 3rd misses, can't figure it out
Old Aug 30, 2013 | 02:51 PM
B_Swapped93's Avatar
Default Re: Cylinder 3 misfire
You can't make two threads regarding your topic. However confirm that cyl 3 injector is firing 2nd confirm spark in cyl 3 if those 2 check out compression test it.
Old Aug 30, 2013 | 02:55 PM
I know I didn't mean to make 2 how do I delete one? I did the injector sprays and it has a healthy spark. To day was the first time it started, built it from the ground up brand new everything. Ok will check compression
Old Aug 30, 2013 | 02:58 PM
Compression test ALL the cyls. and you can just leave it and edit the post to say "DELETE".
Old Sep 9, 2013 | 12:33 AM
Ok sorry for the late reply was busy but did the test and all cylinders are at 120, the valves were to tight had to adjust the valves now it runs perfectly except when I hit the gas it starts to dye......
Old Sep 9, 2013 | 08:37 AM
120 is very LOW ! have you is mechanical timing on ?
Old Sep 9, 2013 | 09:33 AM
I tested it on cold start had very little time but I'm sure when its warmed you its higher
Old Sep 9, 2013 | 01:30 PM
re-do It with the car at operation temp and the throttle wide open. don't forget to unplug the distributer !!!
Old Sep 21, 2013 | 12:21 AM
Ok sorry for late reply the comp test came out to be 175 at all cylinders got it dynoed at 151 hp and 120ft to a bit low how can I increase without turbo I have full exhaust short ram intake ported and polished head wisco forged pistons manley h beam rods supertech dual valve sprins titanium retainers and valve locks as well as a tune any ideas on extra hp without turbo?
Old Sep 21, 2013 | 07:09 AM
151 is way to low for a b20vtec with what you say is done to I,t you should be pushing 200whp easy. time for new rings it sounds like. Healthy b series should push 210+ compression on all cylinders something is wrong with yours
Old Sep 21, 2013 | 07:17 AM
I did get the low compression pistons
Old Sep 21, 2013 | 08:37 AM
ohhh umm then why not boost lol ? you're kinda asking the opposite of what you have your set up for. swap in high comp piston if you want to go N/A if not it's like wanting to turbo your 12:5:1 N/A type r.
Joe Yaerrd
Oct 11, 2016 02:16 PM
Chargerhemi06
17
Sep 29, 2014 06:44 PM
stevedrum4578
Jun 15, 2013 08:08 AM
akstuey
Nov 29, 2011 03:15 PM
nisdat720
Mar 7, 2010 05:39 PM
