Idles fine, turns off with gas
First of all, I ran out of gas the other day. I know, that's stupid and sad, but my GF had my card, and I had planned to get it on my venture home from work.
The car had to be jump started at the gas station, ran fine
Started fine the next morning and I drove it to work, ran fine.
Got to work, started, and turned my lights on, and the car died.
I jumped it off, and drove it home, no problem.
I now can not get the car to start without a jump (I will replace the battery, no biggy)
I get jumped today, let it idle, and when I pushed on the accelerator, it died, instantly.
I'm wondering if it could be fuel pump/filter?
I have a pretty new alternator, idk if it could be that.
Thanks
Thanks
Used a gauge from O'rileys(sp)? today. I was running 30psi through the fuel filter. I revved it a little bit, which was better than what it was usually doing. Before, it wouldn't let me rev at all.
After idling for a few minutes, the PSI dropped to around six. The car slowly begin to sputter to a stop. I will be checking fuel sock tomorrow for crud, just want to hear more suggestions.
I may have had my buddy hook the positive cable onto the ground terminal.. I remember seeing red on negative, but the ground wasn't on the red I also don't know of the other set was connected yet. I wasn't tentively watching them do it.. I'm hoping my electrical isn't shot.
Oh God.
Thanks.
Oh God.
Thanks.
Oh God.
Thanks.
Oh God.
Thanks.
Looks like it got fixed it today.. Had a buddy come by and check it out.
All of this started happening as if it were due to me running out of gas, coupled with a bad alternator.
So after poking around, saw that a nut wasn't on the line running power from the alt.
Threw a nut onto the bolt, and viola! Runs like a champ again.
This would have been a lot simpler to fix if I hadn't of run out of gas... Then I would have suspected the alt a lot sooner. xD
Thanks for the comments.. Hope that maybe this will help someone one day? Doubt this happens a lot though.
Steve90HB
Dec 14, 2003 01:45 AM
