Stalls after reaching operating temperature.
Old Aug 29, 2013 | 12:13 PM
spcasey's Avatar
Icon2 Stalls after reaching operating temperature.
I've got a 1995 Honda Accord DX. Starts great and runs fine until it gets up to normal operating temperature. Then it will stall when coming to a stop. When it stalls it will start up just fine. I've replaced the PCV valve, cleaned the throttle housing, cleaned the IAC and no codes showing up. I replaced the O2 sensor on the exhaust manifold about a year ago. I may replace the fuel filter but I'm pretty sure I replaced it not too long ago. If it wasn't fuel injected I'd think I have a vapor lock situation. I'm starting to run out of ideas. Any help would be greatly appreciated.
Old Aug 29, 2013 | 05:19 PM
crazyhouse2011's Avatar
Default Re: Stalls after reaching operating temperature.
Lean mixture perhaps? That's what comes to my mind. If it runs fine cold then that may be the reason. A cold engine runs rich so it warms up quick and doesn't die. So when the ECU leans out the mixture it might become too lean.
Old Aug 29, 2013 | 11:24 PM
holmesnmanny's Avatar
after the car warms up pull the oxygen sensor connector and engine code will throw a code for it...it's ok that's what you want...if it runs fine without stalling the issue is in the oxygen sensor circuit....if so, i would start with seafoaming to check for an exhaust leak from exhaust manifold to just past the oxygen sensor...if present fix leak and now replace oxygen sensor since it's now bad
if the car still runs bad after pulling the oxygen sensor connector the issue lies elsewhere
JDM_SOHC
Apr 12, 2009 02:38 PM
93 hoopdy
Apr 28, 2008 08:41 AM
jaredvabeach
Apr 16, 2008 02:29 AM
i64X
Feb 18, 2006 01:23 PM
137
Mar 9, 2005 06:28 AM
