Problem with dome light
When the passenger door is open, there is no dome light. Works fine for the driver though! Whats the problem, and how do i fix it??? Thanks guys. BTW, I did a search.
im haveing the same exact problem, same side of the car and everything, but if i push the sensor in and out a few times it works. i guess i gotta buy a new one and replace it. does anyone know how much these go for?
dont replace it. try spraying some wd-40 and working it a bit. that might clean the contacts enough. if you cant get it to work i got mine for my 91 for 2$ from a junk yard.i used a drivers side. dont forget your passenger side doesnt open as often so the switch sits for longer periods of time.
This seems to be a common problem with the G2 Integra's. WD40 will help for a few months.. after about a year tho the door switch seems to quit working. Call some junkyards.
ajpturbopittsburgh
Honda Civic (2001 - 2005)
Dec 17, 2008 06:14 PM
nc_jon
Dec 9, 2008 04:37 PM
