Problem with dome light
Old Oct 25, 2002 | 03:50 PM
Grandprix's Avatar
Default Problem with dome light
When the passenger door is open, there is no dome light. Works fine for the driver though! Whats the problem, and how do i fix it??? Thanks guys. BTW, I did a search.
Old Oct 25, 2002 | 04:29 PM
jdmotorsports's Avatar
Default Re: Problem with dome light (Grandprix)
check the switch for rust or broken connection.
Old Oct 25, 2002 | 10:34 PM
far's Avatar
far
im haveing the same exact problem, same side of the car and everything, but if i push the sensor in and out a few times it works. i guess i gotta buy a new one and replace it. does anyone know how much these go for?
Old Oct 26, 2002 | 12:46 PM
Default Re: Problem with dome light (far)
dont replace it. try spraying some wd-40 and working it a bit. that might clean the contacts enough. if you cant get it to work i got mine for my 91 for 2$ from a junk yard.i used a drivers side. dont forget your passenger side doesnt open as often so the switch sits for longer periods of time.
Old Oct 26, 2002 | 02:39 PM
94TealGSR's Avatar
This seems to be a common problem with the G2 Integra's. WD40 will help for a few months.. after about a year tho the door switch seems to quit working. Call some junkyards.
mdh111
Dec 6, 2016 11:40 PM
user 8508202243
Apr 29, 2012 03:33 PM
ajpturbopittsburgh
Honda Civic (2001 - 2005)
Dec 17, 2008 06:14 PM
nc_jon
Dec 9, 2008 04:37 PM
Neptune
Feb 1, 2004 06:17 PM
