Need help with clutch
Old Aug 28, 2013 | 11:57 AM
aj345's Avatar
Default Need help with clutch
So today ive noticed that my ls tranny started to make a what sounds like a high pitched squeak. It happens when clutch is not pressed in, but once you press it in, the noise immediately disappears. You dont even have to press the clutch to floor to make the noise disappear, you can hardly press it at all and it goes away. Any thoughts, im thinking the most obvious throwout bearing but people said if the noise goes away when you press in the clutch, its a bearing inside the transmission. I just dont know cause you can just light touch the clutch and the noise is gone.
And one other symptom that may or may not be related, at high rpms literally right before redline, I hear what sounds like hundreds of metal pieces shooting around. dont know if that has something to do with tranny or not.
Thanks in advance
Old Aug 28, 2013 | 12:18 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: Need help with clutch
Throwout bearing needs replacing.
Someone correct me if im wrong.
Old Aug 28, 2013 | 12:19 PM
Shit Posts: 15
10 Year Member
As for sll the clatter at high rpms. That doesnt sound good.
Remove your oil pan and see if you find metal pieces, also drain your trans fluid to see if metal shavings come out n
Old Aug 28, 2013 | 12:21 PM
kyden's Avatar
internal bearing. not throwout bearing. a throwout bearing would make noise when you push the pedal in.
most likely input shaft bearing, but it can be any bearing inside.
Old Aug 28, 2013 | 12:26 PM
aj345's Avatar
I was thinking input shaft bearing but the noise goes away when the clutch is barely pressed in, like I dont have to press it to the floor, the motor can keep turning and everything.
Old Aug 28, 2013 | 12:37 PM
kyden's Avatar
doesn't matter how much it's pressed in.
Old Aug 28, 2013 | 01:44 PM
aj345's Avatar
So does that mean the tranny is toast because it was just rebuilt last year. Is is hard to replace that bearing?
bbrian
Jun 11, 2013 05:07 PM
beoy9
Nov 1, 2007 01:52 PM
integra15
Jul 27, 2006 10:36 AM
nY's FiNeSt
12
Oct 22, 2003 04:06 PM
Cosworth
Aug 23, 2002 03:02 PM
