Transmission & Drivetrain Gearboxes, Differentials, Clutches
b16 lsd no worky worky!!! need help asap
Old Aug 27, 2013 | 11:40 AM
wicked_jeb's Avatar
Default b16 lsd no worky worky!!! need help asap
ok so my car has a b16 lsd trans in it however the other day when I had the front end lifted off the ground I noticed something that I am not sure about.
So both tires off the ground.
Transmission IN NEUTRAL: (spinning one tire at a time)
D/S tire spins freely
P/S tire spins freely
Transmission IN GEAR:
D/S tire does NOT spin
When I stomp on the gas I notice that only my D/S tire actually spins and the car pulls EXTREMELY hard to the P/S.
My P/S axle does not look broken in any way. I ordered outter tie rod ends that will be put on the car this weekend.
Any other ideas/suggestions on what could be happening? I hope my trans is not shot.
Old Aug 27, 2013 | 06:37 PM
wicked_jeb's Avatar
Default Re: b16 lsd no worky worky!!! need help asap
108 views and not a single thought?
Old Aug 28, 2013 | 04:43 AM
wicked_jeb's Avatar
Old Aug 29, 2013 | 03:47 PM
wicked_jeb's Avatar
ttt
Old Aug 30, 2013 | 05:56 AM
wicked_jeb's Avatar
up again
Old Aug 30, 2013 | 02:56 PM
wicked_jeb's Avatar
up up and away
Old Sep 3, 2013 | 02:46 AM
rd91sib18c5r's Avatar
What kind of lsd is it? If the diff was broken it wouldn't drive.
Old Sep 3, 2013 | 12:04 PM
wicked_jeb's Avatar
I am not sure what diff is in it. I just know its got the b16 trans in it and its stamped (not ink printed) LSD on it. I am gonna pull the axles this weekend and verify its lsd using the "look thru the hole" method lol. If it is a hollow hole like the lsd should be, could it possible that its my axle?
Old Sep 9, 2013 | 11:55 AM
wicked_jeb's Avatar
update: So I changed out my tie rod ends to try and help with the hard steering pull problem. Helped a little but still doing it under high acceleration shifts. when trying to accel out in front of traffic, only my DS is spinning still.
I think I am just gonna try and find another trans for right now and pull the other one completely apart and see whats going on....
gophat
Sep 2, 2006 09:27 AM
lastpunkinline
May 27, 2006 03:56 PM
b16a27
12
Oct 26, 2004 08:25 PM
steebypue
Sep 11, 2003 11:03 PM
EF_LSVtec
16
Sep 18, 2002 10:59 AM
