93 hatch b18b1 swap gas cap question
Old Aug 27, 2013 | 05:47 AM
Dynastro's Avatar
Default 93 hatch b18b1 swap gas cap question
Like title says I have a 93 dx hatch with a 95 b18b1 motor and gsr trans, car runs great no problems with swap, but my question is, should I have a vented gas cap or non? I'm using the stock cap but it seems to build up pressure when I drive, and releases a lot of fumes when going for fill up, I know this isn't a pressing matter but seeing if this is normal or what. Thanks for your help
Old Aug 27, 2013 | 07:35 AM
slomofo's Avatar
GDD Member
Default Re: 93 hatch b18b1 swap gas cap question
The pressure is supposed to be there, it's functioning properly.
Old Aug 27, 2013 | 10:22 AM
Dynastro's Avatar
Thank you for that, I was just wondering because my other cars don't have pressure built up like my hatch.
Old Aug 27, 2013 | 12:40 PM
dirty19's Avatar
Ridin Dirty in Cali
Make sure your charcoal cannister is connected and working.
Old Aug 27, 2013 | 04:49 PM
Dynastro's Avatar
So if my canister is removed I should be ok correct? I don't have gas fumes under hood or any running issues, In fact the motor was just rebuild back to oem specs using all Honda/Acura parts.
Old Aug 27, 2013 | 04:52 PM
B_Swapped93's Avatar
It's ok to remove the EVAP stuff so long as you plug the lines including the one going to the tank(hard line). that's what I did on my 94 gsr.
Old Aug 27, 2013 | 05:00 PM
Dynastro's Avatar
Ok cool that's how I have it, thanks
turboef90
Apr 20, 2009 07:18 PM
oes
Aug 7, 2005 09:23 AM
88crxhfb16
Jun 1, 2005 09:15 PM
Scotty Dosent Know
May 9, 2005 12:53 AM
.ShawnD.
12
May 2, 2004 04:36 PM
