93 hatch b18b1 swap gas cap question
Like title says I have a 93 dx hatch with a 95 b18b1 motor and gsr trans, car runs great no problems with swap, but my question is, should I have a vented gas cap or non? I'm using the stock cap but it seems to build up pressure when I drive, and releases a lot of fumes when going for fill up, I know this isn't a pressing matter but seeing if this is normal or what. Thanks for your help
Re: 93 hatch b18b1 swap gas cap question
So if my canister is removed I should be ok correct? I don't have gas fumes under hood or any running issues, In fact the motor was just rebuild back to oem specs using all Honda/Acura parts.
It's ok to remove the EVAP stuff so long as you plug the lines including the one going to the tank(hard line). that's what I did on my 94 gsr.
turboef90
04-20-2009 07:18 PM
88crxhfb16
06-01-2005 09:15 PM
.ShawnD.
12
05-02-2004 04:36 PM
